Sprint2 rear diff fix
I read a few places that to avoid destroying the belts on my rear diff I should cut the diff cover but the only pictures I've seen so far of where to cut did not look like my rear diff... Any suggestions or help is greatly appreciated.
Is it new or used? The new ones have orange anodized metal instead of the original purple and the new version should already have It's bulkheads modified so you don't have to do it yourself but not all the new ones have this done if their not modified your best bet is to go online and order two sets of bulkheads Hpi redesigned them finally and they come without the outer plate that you would normally have to.remove but if you can't spend maybe 15 bucks online then do it yourself It's no trouble really Ive done it twice myself and a few times for friends with sprint 2's but do be warned your bulkheads lose some structural integrity when you do this even if done right I've broken both sets of self modified bulkheads so I would really just buy the new stock modded ones
Here you go hope this helps http://www.rcuniverse.com/forum/m_78...tm.htm#7910471
ORIGINAL: egoods
