RC Drifting Discuss all aspects of rc drifting here!
Problem with stuck screw !
Old 05-07-2005 | 01:54 AM
Default Problem with stuck screw !
Problem, on my on road losi touring car 1\10 , an allan screw is stuck in, and the the head is dammaged, the screw is on the bottom of the chassis and holding the shock tower, the allen key is not grabbing it , it goes loose in it, WHAT ARE MY WAYS TO OPEN IT AND I DONT HAVE A DREMEL.
thanx
*living from run to run*
Old 05-07-2005 | 02:45 AM
Default RE: Problem with stuck screw !
Well a dremel tool is always my first suggestion in this matter. However; I have another, cheaper, solution. You'll need: CA/Super Glue, and a hex wrench. Step one: place a few drops of CA/Super Glue into your galled hex head bolt. Step two: Place your hex wrench into the hex bolt and let the wrench bond to the bolt for the recommended curing time of your particular glue. Step three: Twist that sucker out of there and you're home free!
Old 05-07-2005 | 02:46 AM
well bro i had the same thing happen on my ntc3...try to find a dremal..if you cant find one ask around for a friend with any kinda drill press...if you cant find one from a friend look in you phone book for machine shops and tool and die shops in your area if you bring it to them they can get it out...normal for a small fee (ie) 5 buck or maybe free???..also if all els fails put a sma;; amount of J B liquid weld in screw head and stick old wreanc in and let it dry......id try the machine shop they mite be able to help you in the future
Old 05-07-2005 | 03:52 AM
ORIGINAL: dsmfreaks
