NEED HELP GETTING A DRIFTER
TN
hey guys im wantin to get into some drifting action. i was thinking a trinity T-Spec over a TT-01 because it comes with oil filled shocks and its shaft driven and looks alot less complicated than a TT-01. what do yall think? should i get one? tell me what yall think of this idea.
Banned
CA
First off, you're gonna get a lot of people who are gonna push the TT-01. I would actually get the T-Spec over the TT-01 for the reasons you mentioned, plus the fact that the suspension is fully adjustible. It also comes with an aluminum drive shave and CVD's. Although the T-Spec doesn't have the parts support that the TT-01 does, I'm sure you can use parts from other cars when the time to replace broken pieces comes. Just my $0.02
MD
well i have a tt-01 and upgraded to oil filled never even put the fiction shocks on they havn't even been put together and i am going to be upgradeing to an aluminum drive shaft and a reedy mvp i haven't heard much about the t-spec but i assure you that the tt-01 is not that complicated you just need to know what you are doing and you will be fine
good luck
good luck
TN
hey thanks guys for your help and i got one question for strictlynitro. how much does your TT-01 cost after you put the oil shocks and aluminum shaft? thanks.
