drift engine question...
ok i have an rs4 3 with a busted engine[:@] but im used to big bashers and big engines i have a brand new in box *updated* sh.28 but apparently that is too big for my rs4. so im looking for some guidance on which engine i need to burn some rubber[>:]
Banned
CA
A larger engine will just throw the car's balance off. I would personally go with a nice .12 with a low end torque header and a midrange power pipe. The .12 will allow for a more neutral steering feel. Also, drifting doesn't require massive power, especially if you're planning on running ABS, PVC, Yokomo ringed tires, etc.
i told ya'll fuk pvc and abs on nitro's use yokomo ruber or tape. the t-15 would be good or the 1 your using now the hpi.12fe no o.s. yu'll just break the engine[sm=RAINFRO.gif]
ORIGINAL: qaz393
collari has came out with the the .32. btw, is it the wolfpack conversion
for major power and speed!![>:]
