RC Drifting Discuss all aspects of rc drifting here!
which speed controller?
Old 12-16-2005 | 06:24 PM
Goaferboy's Avatar
Default which speed controller?
iv just ordered a kit and im just ordering the rest of the stuff i need. iv ordered the yokomo drift kit.
which is better? forward/brake or forward/reverse?
also which battery would be good/fit this kit? im totally new to electrics
Old 12-16-2005 | 10:00 PM
GraTou's Avatar
Default RE: which speed controller?
get an ESC that has foward and reverse, preferbly something by Novak (check out Towerhobbies.com for them)
a nice mAh 3600 or 3800 pack would be nice
Old 12-16-2005 | 10:25 PM
For an ESC, Usually Forward only's are better, but if you really want the ability to go reverse, then go for it.
Reverse ESCs usually cost more, but if you've got money, spend it.
I have a reverse ESC in my HPI pro 3 and a Forward only ESC on my TL-01. You may think that not having reverse might be a disadvantage or you think that you might feel crippled without going in reverse, but it's not that much of a deal since the majority of the time... you'll be going forward. Well, I hope you're going forward...
But anyways, these are probably gonna be your options if you're looking at ESCs less than $50USD.
I have this one on my TL-01, and it's great. The high frequency and no reverse keeps my motor cooler than it would with my Reverse ESC. (12t limit)
http://www2.towerhobbies.com/cgi-bin...?&I=LXD523&P=7
This is probably the cheapest price you'll get for an ESC. It's forward only and does it's job well! (20t limit)
http://www2.towerhobbies.com/cgi-bin...?&I=LXAXT7&P=7
Probably one of the cheapest Reverse ESCs out there. Also does it's job well. (18t limit)
http://www2.towerhobbies.com/cgi-bin...?&I=LXGZX1&P=7
This one looks similar to mine, and is one of the cheapest Reverse ESCs out there. (20t limit)
http://www2.towerhobbies.com/cgi-bin...?&I=LXAMN7&P=7
The reverse ESC I got was the cheapest one i've seen in my entire life. It was $30, and i've only seen it at my LHS. I can see why it was so cheap though. I can't even reprogram the damn thing anymore, but it still does it's job...
Now with batteries... for starters or just drifting, the standard for almost all touring cars is a 7.2v, 6-cell, 1200mah or more, Ni-cad or Ni-mah, stick type battery.
Most people look at this battery, as it is cheap, has high capacity(3000mah), and is Ni-mh(nickel-metal hydride).
http://www2.towerhobbies.com/cgi-bin...&I=LXERB5&P=ML
Or if you've got a radio-shack near by, you can get a 3300mah battery for $25.
Now, you'll need a charger for your batteries. I HIGHLY suggest getting Ni-mh batteries BTW. Less more maintainance and much more running time than Ni-cads. Ni-mh batteries will be 3000mah or more and Ni-cads never will surpass 3000mah, so that's a little info to check wether it's nicad or nimh.
For a charger, you probably want an AC charger(a charger that plugs into a wall). Also, if you decide to get nimh batteries(which I hope you do), make sure the charger can charger nimh batteries. If it doesn't say it chargers nimh, then it doesn't. Don't take the risk and waste money or ruin your batteries. Also, watch out for cheap chargers, as they may charger nimh battereies as they would say, BUT IT MIGHT SAY DC CHARGER, NOT AC/DC CHARGER. This means it will only use a DC power supply! That means like on the battery of your car! MAKE SURE IT'S AC/DC CHARGER UNLESS YOU KNOW WHAT YOU'RE DOING.
So anyways, this is probably what you want.
http://www2.towerhobbies.com/cgi-bin...?&I=LXCLD5&P=7
Just read and see. Exactly what you will probably need.
Now onto the motor. The motor is pretty much your engine... An ideal motor for drifting is a 27 turn motor. The lower turn the motor is, the faster. The thing is, with lower turn motors, the downfalls are...
1. An ESC to take that much of a low turn motor which is very expensive(Lets say an 8t motor, AT LEAST $75)
2. Lower running time because it uses much more power
3. You lose torque, which you need for drifting. A 19t motor is the limit for drifting, meaning any motor under 19 turns, probably won't be able to drift. And if you do, it won't be fun... I have a 19t motor, and I do not like to use it for drifting because you cannot drift without going very fast...
4. There's no reason to get one unless you're going to really race.
So, you're looking at a 27t motor here. Your options would probably be...
P2k2 motor. I have this. It is awsome.
http://www2.towerhobbies.com/cgi-bin...?&I=LXAVJ2&P=7
This is pretty much the same as the P2k2, just with higher torque. I also have this.
http://www2.towerhobbies.com/cgi-bin...&I=LXDDA1&P=ML
Or any other 27 turn motor you can come across... lol... Keep in mind that with these types of motors, you will need solder leads. You will probably want to get these though.
http://www2.towerhobbies.com/cgi-bin...&I=LXTJ21&P=ML
These are no solder leads. You just shove them on your motor leads so you don't have to solder anything! And plus, they've got bullet connectors, so they'll connect to all of those ESCs I mentioned earlier!
Now this thing here is also an ideal drifting motor.
http://www2.towerhobbies.com/cgi-bin...?&I=LXGE34&P=7
Even though it is not as powerful or anything, it will do the job. I drifted my TL-01 with my P2k2 motor. Sure it's great and all, but when I installed my Stock 540j motor in my TL-01 and drifted with it, I was amazed by how evenly they both drifted! Now you see, THIS motor is an UPGRADED version of a stock 540j motor! With this, you may probably get the same or better results drifting than the other 2 motors I mentioned above. It's also got buller connectors installed to, so no need to buy solder leads!
I assume you know about what radio gear you wish to get, but if you don't, there's not much to talk about radios, but here's a pretty cheap one that will do the job.
http://www2.towerhobbies.com/cgi-bin...I=LXCFW2**&P=7
Have fun!
Old 12-17-2005 | 03:42 PM
Goaferboy's Avatar
thanks for all the help. iv already got a p2k2 motor on the way. the rest ill buy as i need it. i think ill get a reverse esc then since iv driven nitros before and the lack of reverse annoyed me a little bit.
Old 12-17-2005 | 05:06 PM
Goaferboy's Avatar
iv ordered everything except for the radio. iv found one that comes with transmitter, reciever and 2 servos. i assume it has 2 servos cos its for nitro cars. will an esc work in place of a servo or will i need to get a package that only comes with one servo?
Old 03-12-2007 | 11:25 AM
Has anyone tried the Tazer 15T Forward/Reverse ESC from Dynamite?
It's only $29.99
[link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=DYN4925]http://www.horizonhobby.com/Products/Default.aspx?ProdID=DYN4925[/link]
The Tazer 15T can handle a wide variety of motors from stock to 15-turn limited modifieds, Setup is push-button simple and it comes prewired with universal Tamiya and bullet connectors.
Old 03-12-2007 | 12:55 PM
i run a tazer 15t on my back up drift car. im using a team orion drift machine 18x3 . so far its the best bang for the buck and it has lifetime warranty.
Old 03-12-2007 | 05:33 PM
itsnotskidding's Avatar
when i buy a esc i like to go as low as i can, i use unlimted esc, mainly because they can be used with any turn motor if needed, i use a 19t motor but it also makes the esc run alot cooler, as there is not any work for it to realy do, they can be bought fairly cheap...
ive always used lrp... 100% perfect, never let me down yet and i race also with there equipment so i no they stand up well, if i ever went brushless i would prob go with the above gratou... novak
they hold up well and also look awsome..lol,
you only need one servo and reciver, one esc and one transmitter...
Old 03-12-2007 | 06:23 PM
I too buy the Lowest Turn Reversible ESC I can buy..
RCLINE PC Series No Limit ESC
Duratrax Intellispeed 8T Reverse ESC
M-Troniks RV11 ESC.
I am Not a BIG fan of the LRP AI ESC's they just dont seem to provide enough punch to the motor for my likeing..
Old 03-12-2007 | 07:34 PM
Rs43EVOman's Avatar
Most of the guys i know run the Novak XRs,and im surprised it hasnt been mentioned alot on this thread. Only $50,a nd it does eveything the slightly cheeper ESc's do (it has reverse), but its definelty alot more responsive.
Old 03-14-2007 | 08:40 AM
bigboi328's Avatar
why go with as low as you can and spend $100 on a esc----i am running a max amps 12.000 mah lipo and a castle creations mamba max esc the does brushed and brushless----the brushed can handle any motor ( no turn limit ) and it has a programable throttle and brake curve----i can adjust fwd only-fwd-brake-rev ---drag brake -abs brakes-punch control and more---check out there web site castlecreations.com and you can pick up a complete system for $180 at www.b-p-p.com
Old 03-14-2007 | 09:07 AM
wow...
that is a good offer!!.. $180 is about £90 english money and my lrp's are £100 a time, wow, thats crazy cheap...
thanks for the link dude, i will surely be looking into one...
Old 03-22-2007 | 01:25 AM
blazenevader's Avatar
my tazor 15t esc over heats with mt 15t flash motor. i'm getting this one soon. http://www2.towerhobbies.com/cgi-bin...?&I=LXAXT9&P=K
Old 03-22-2007 | 07:28 AM
ORIGINAL: Rs43EVOman
True,
Very good ESC for the Money,
U might want to check out the Novak XRS!
