front wheel problems please help!!!
i just got done drifting outside, and i noticed that when im turning the front wheels vibrate violently, and i just got abs yesturday. abs works great! but the front wheels are just to shaky. its not hitting anything in the inside. i guess its off ballance? idk. my tires are also not laying flat on the ground, maybe thats got sumthing to do with it. please help me
maybe you didn't tighten the wheels on tight enough?? or maybe the ball cup that your axle goes in is cracked or broken or something??
Your wheels shouldn't be loose. My suggestion is to tighten down your wheel nuts. But, you may be having the problem I'm having, where my wheels spin faster than my tires and it creates a nasty noise/vibration. but, I'd try tightening down the nuts first. Then see what happens.
