Drift Tires
Is it true that you can make any 4wd car drift, like a TT 01 or something just by putting PVC and ABS? tires on the car
And If so Where can you get them from and how do you fit them>
?And If so Where can you get them from and how do you fit them>
Banned
Plumbing Store.
50mm PVC/ABS
Cut to width of your Rims (preferably 2mm wider for rim protection)
Wrap the Bare rims with Electrical Tape till the Centre of the Rim is about 1mm Higher then the outer rim wall
Grap Your PVC/ABS Pipe and Warm them in Boiling Hot water or in a Fan Forced oven Set at about 150Degrees C and Keep Checking them till they are Just Soft and Spongey
Quickly Grap the PVC/ABS and Ram them over the Top of the Rim with a Quick Forceful Pressing down Action and BAM
PVC/ABS Cools and Shrinks over the top of the Rim and Electrical Tape without the need for Glue
To Remove, Drift them down till the rim just Shows then cut them off
50mm PVC/ABS
