RC Drifting Discuss all aspects of rc drifting here!
novak over heating problem
Old 08-03-2006 | 05:21 PM
Default novak over heating problem
hi i have a novak esc that i just took off my losi xxx-s, and i think its been having some over heating isues. my novak has been shutting itself off after 5 minutes of play because of over heating. do novaks have a thermal shut down on them. like when they get to hot they shut them selves off? well i was wondering if it was my gearing. i have a tt-01 and im using all the stock gears, and im using a trinity 19t motor, should i buy different gears? i really need some help.
Old 08-03-2006 | 05:46 PM
Default RE: novak over heating problem
ok i found my problem, it has a thermal overload protection on it. [link=http://www.hobbypeople.net/gallery/551731.asp]http://www.hobbypeople.net/gallery/551731.asp [/link] how can i make it so it doesnt overheat? or will this stand to the overheat [link=http://www.hobbypeople.net/gallery/383420.asp]http://www.hobbypeople.net/gallery/383420.asp[/link]
Old 08-03-2006 | 06:11 PM
Banned
Swap to a 22T pinion on the Motor and Re-install the motor on the Motor mount.. That Should At least help..
Old 08-03-2006 | 06:14 PM
sorry im new at this. but what would swapping to a 22t pinnion do? and what about the LRP Quantum Runner Reverse Speed Control.
Old 08-03-2006 | 06:23 PM
Banned
The LRP Quantum is a Great ESC, Swapping to the 22T pinion will allow the motor to Rev out a Tad more yet still keep your Torque Range Nice for Drift..
Just Allows it to take a Little Torque load off the motor which Should cool things down a little..
Old 08-03-2006 | 06:29 PM
alright,i think i should go to the store and get a 22t pinion but i think i should get a LRP Quantum Runner Reverse Speed Control and if the 22t pinion solves my problem ill return the esc.
Old 08-03-2006 | 06:31 PM
Banned
You will need a Tamiya 22T pinion.. Tamiya Gears are Suited to the TT-01 as Tamiya Use a different method of Measurement to other companies
Old 08-03-2006 | 06:38 PM
ok thanks alot
Old 08-06-2006 | 10:39 PM
When your looking for a pinion for the Tamiya, make sure its 48 pitch (48P) METRIC. If it's not METRIC it wont work.
Robinson Racing sells pinions that are 48P metric.
