4-Tech drifter
ON, CANADA
yeah, real simple, buy some abs pipe make youself tires and go drift. if you ahve rims already thats free, and pipe costs like what? 1$ or so per foot?
You could do that, or if you want to spend more than $1, you could buy stage-D tires. I find that the !QUOT!real!QUOT! tires keep your over-steers less frequent and give you more control. The pipes can't make good transitions when making a S-turn or drift well on uneven or down hill tracks.But that is just me. Drifting is like a fingerprint, everyone's is different and unique.
Banned
Word that, Every one is Different...
I find on most surfaces, unless you have a low Turn motor, Drift Radials Will Bounce..
ABS is all You need to Drift and Drift nicely on Smooth Tarmac or Concrete even with a Stock motor and stock diffs
Traction is the Enemy of the Drift, you need a little but not alot to drift with ease..
Yok drift rings have the most control that i've found without giving too much traction. I don't use them anymore cuz they're a pain to put together but if I had patience I would. using abs or pvc will get you there. You're gonna spin a lot tho until you get the hang of it. Just a heads up.
NY
well i went to the hardware store to get some pvc. but they said it was illegal in manhattan. the guy said he could get some on tuesday
Banned
Chlorine
Pvc has an amount of Chlorine in it.. (dont shoot me If I am incorrect as it was I was told)
Some places out law it Based on this..
Black Polypipe is Better, Irrigation pipe. 50mm Internal Daimetre or I think it is 65mm External Diametre...
