RC Drifting Discuss all aspects of rc drifting here!
paint removal?????
Old 09-30-2006 | 03:49 AM
rct
Default paint removal?????
ok chaps i have just got my r34 light buckets in th epost 2day and i was wondering what is the best way to remove the paint from my body shell around where the buckets will go????
i have some IPA and will give that a try, but is there any other method that is not so abrasive and that wont affect to much the area around the buckets????
Old 09-30-2006 | 12:35 PM
rct
Default RE: paint removal?????
dont worry i sorted it
i used one of the polishing pads from my dremmel.
use it dry and just be very carefull as it gets hot and can distort the lexan.
once the paint is off use a polish compound that you can use on glass and mine came up ok.
please note use at you shells risk i will not be held responsible if you kill your shell.
ooops forgat to say make sure u mask off the surrounding area that you dont want to come off.
