RC Drifting Discuss all aspects of rc drifting here!
Throttle Pulsing
Old 12-06-2006 | 07:38 PM
Banned
Default Throttle Pulsing
Here is a Really Lame Vid to Show You how to Pulse Your inputs to Hold Your Slide..
Do Both at the Same Time Only After You have initiated Your Drift..
Constant Adjustment is needed to keep Your Tail out and to stop spinning out..
The Controller I am using is the Stock Controller from a HBX TL-01 to Show You, they do actually Pulse properly lol
a Better Vid with the Pulsing Action in Action will come at a Later date
Old 12-07-2006 | 02:48 PM
speenair's Avatar
Default RE: Throttle Pulsing
That was educational
Old 12-07-2006 | 03:50 PM
[sm=what_smile.gif][sm=what_smile.gif][sm=what_smile.gif][sm=what_smile.gif][sm=what_smile.gif][sm=what_smile.gif][sm=what_smile.gif][sm=what_smile.gif][sm=what_smile.gif][sm=what_smile.gif][sm=what_smile.gif][sm=what_smile.gif][sm=confused.gif]
are you for real?
Old 12-07-2006 | 04:16 PM
Banned
As I said.. It was lame.. I will get the Proper Vid of the Pulsing in action soon...
It is Far easier to see it in person then to try and Capture it on Video..
Old 12-07-2006 | 05:16 PM
i wont say anything, because thats what i used in 1:1 scale, especially when it was very loose or wet and i was constantly loosing too much traction...
but ideally shouldnt you just hold constant lower levels of throttle through the turn *not at the initiation of the turn*... its more difficult but should it in theory create a smoother drift?
Old 12-09-2006 | 11:22 PM
^^^ smoother drift = good
it also helps to alow you to drift longer. ie batteries won't run down as quickly due to lower load on them from the constant on-off-on-off torque draw.
BV
Old 12-16-2006 | 02:12 PM
rcluke's Avatar
it was like some geeks porno video!!!
Old 12-16-2006 | 05:54 PM
Banned
Your right.. Been Deleted
