tyre tips
hey all ive been on other forums and had ppl complainin bout how thier tyres ( yokomo's , PVC's or ABS ) start coneing. Well before anybody asks why this happens ill tell you..
It is caused by the setting of the camber on your car you may either have too much positive camber or too much negative camber for drifting you need to have a zero camber, zero camber prevents the tyres from coneing......hope this helps
Banned
Zero Camber I have found is Also good for Racing.. The Contact Patch is Bigger, so although it may slow you down a little, You can take the Corners Harder... much like RC Drift lol
