Tamiya XB question
FL
http://www2.towerhobbies.com/cgi-bin...?&I=LXPFD6&P=0
If I got this car what upgrades should I look into...I dont really know what much of the stuff means so I dont know what it has and doesnt have...
Also, are there any other RTR cars on tower i should look at opposed to this one...
thanks
thanks
Tamiya parts that really help:
1. Ball bearings
2. Metal motor mount
3. Carbon Fiber upper brace
4. Sway bars
5. Steering kit
The bearing are by far the most important. After I put them on, my TT-01 did not want to stop. It was hungry for speed.
The upper brace helps with lessening chassis flex. It's a big help.
1. Ball bearings
4. Sway bars
5. Steering kit
ORIGINAL: MoB KyotE
up the shaft to an alum. one
Then just upgrade it all in one go
Psycho, I'd have put 3 of your choices much further down the upgrade route than that. I'd do:-
Ball Bearings, CVA shocks and Aluminium/carbon propshaft
Steering kit
Adjustable Arms
Carbon Fibre Upper brace
Sway bars
A decent ESC with either a Team Orion Method R 15x2 OR a Mamba Max 5700 (and buy a new pinion gear to lower the ratio until you learn to cope with the power, and another one for after that when you will inevitably want to do a high speed run
)And then some decent batteries+ charger.
