Nitro Driftcakes! :)
ORIGINAL: sajuuknightfall
where did you get that body its so real.. did you have someone paint that for you?
OK
The reason I only did them down one side is because it didn't look right on the other side given the way the arrows swoop in with more weight on one side. I printed out a number of black sticker sheets and then used the xacto knife to cut out arrows. I kept cutting them and placing them until I came up with this configuration, I just wasn't happy with anything I came up with for the other side. I figured I'd use stickers or mix it up some other way. I also made a mistake putting two arrows down the right side I think I should have only used one larger one and had it arc up then down pointing toward the rear wheel. HPI doesn't supply very good decals with their bodies so I was mixing and matching a number of things from a number of bodies. The spoiler on this r34 actually came from a 350 Z. I just painted it white and stuck it on
lol still looks great man
