mamba max
TX
Which mamba system is everyone running? I want speed so i can haul @$$ when i want but i want the torque to drift as well when the time comes. I know it depends on the battery your running and how you have it tweaked. I just know some run others becasue the others may not perfrom as well. Suggestions?
BC, CANADA
i run 7700kv. punch control 100%. 15 minute run time. Too much power and I use 1/7th of the throttle available. For drifting get 4600kv. If you want speed get 460Kv. its faster than a 7700kv and you can go on 4C lipos with it if u disconnect the bec (the red wire inbtween the brown and orange) and use a 6v external bec or 6v reciever pack. It can reach speeds +75mph in a buggy
ORIGINAL: sloshedmr_bones
no body has information on a brushless system. When thats a big convo i have seen on here.
