RC Drifting Discuss all aspects of rc drifting here!
TC4 Drift Setup?
Old 04-27-2007 | 05:18 PM
Default TC4 Drift Setup?
How should i set up a TC4 drift wise.
Old 05-01-2007 | 10:54 PM
Default RE: TC4 Drift Setup?
I drift my TC4 and it's pretty great at what it does stock. However, I just dropped an Epic double wound 16 turn and a new ESC in. I also bought 5-spoke chrome HPI wheels and made custom aluminum tires for drifting. I've never heard of anyone using aluminum for drift tires. It works pretty well though, but I've heard ABS is the best material for making drift tires, and of course if you can't come by ABS, PVC tires seem to work for a lot of drifters.
Old 05-02-2007 | 03:40 AM
Aluminium Tires???,
Thats a nice idea,
I use to use brass tubing for tires as a little test they work good, better then Aluminum cause their softer!,
About that a 16t double and Alumum i got to hand it to you!
Old 05-06-2007 | 04:54 PM
in my tc4, i used a Novak XRS esc, co27 motor, cambers set at 0 all around, ABS as tires, set the shocks stiff, and a heat sink.
