RC Drifting Discuss all aspects of rc drifting here!
Entry Level Drifter Build
Old 05-04-2007 | 01:20 AM
HoldDaMayo's Avatar
Default Entry Level Drifter Build
I just ordered:
Subaru WRX TT-01 kit
ball bearings
alum drive shaft
metal motor mount
motor heat sink
These wheels and tires http://www2.towerhobbies.com/cgi-bin...Z0&FVPROFIL=++
I already have a GP3300 6 cell battery pack and peak charger and Spektrum DX3 radio system with a couple servos.
With the setup I have, should i be able to do some alright drifting? The only piece i wasn't sure about was the motor. I'm interested in being able to use this car with a normal driving and drifting, any ideas of a motor that would be good performance for drift and grip driving?
Thanks.
Old 05-04-2007 | 02:47 AM
Default RE: Entry Level Drifter Build
I would go for a Trinty Speed Gems Cromoduim(16t Double), Or any other 16t double,
Its good for those tires,
other then that ur set-up looks perfect for Good driftin not Ok driftin!,
WELCOME TO THE SLIDEWAYZ CLUB![8D]
Old 05-04-2007 | 09:27 AM
i've got the same car with the alum shaft and ball bearings. i up graded to the mamba max 5500 system with the drift spec tires. it's a world of fun. i highly recommend it. oh and also don't for get to lock or put heavy weight oil in the rear dif.
Old 05-04-2007 | 09:47 AM
TIGER76's Avatar
The stock sliver can motor will be fine for drifting and those tyres will help too if you change your motor you will have to upgrade your ESC too (unless you have already) costing more so no need really for drifting as for running it around you will find the stock motor slow []
Old 05-04-2007 | 12:13 PM
yes the stock motor is hella slow! upgrade it and if you can, go brushless
Old 05-05-2007 | 12:42 AM
Not brushless, with a TT-01 ur carzy!,
Its an Overkill Face it!,
The silver can is fine with PVC and a 16/15t for hard rubbers!
Old 05-05-2007 | 11:05 AM
haha the "silver can"
Old 05-05-2007 | 07:27 PM
I´m an entry level drifter too, and I´ve just purchased a Novak XRS esc, and Team Orion Method R V2 19x2 motor, and the same hop-ups as you have on my TT-01R. And don´t waste your money in those drift tires, just put PVC on your wheels.
That´s a GREAT combo for drifting for a very good price
Old 05-06-2007 | 03:53 AM
ORIGINAL: ravenlunatic
It will work good with PVC and for a newbie its fine,
Sorry if i offened ur choicebut im just showin my opinion,
we all have our own opinions![8D]
Old 05-06-2007 | 03:55 AM
ORIGINAL: bowe
I got to admit thats a great way to start!,
Good Advice, Nice Set-up and a Helpful driver!----3 in 1.....LOL
Old 05-06-2007 | 01:42 PM
mugenx's Avatar
imho its hard to hold long slides with the tamiya drift tires. Your better off with some ABS.
Old 05-07-2007 | 08:06 AM
^^^Agree ABS or for the Silver can PVC!
Old 05-07-2007 | 07:21 PM
u can get away with a 19t on grippier tyres wioth the standard tamiya esc, if u get abs u can push it to 16t.
Old 05-07-2007 | 08:12 PM
HoldDaMayo's Avatar
more and more i'm interested in drifting on rubber tires...
Would this do the trick?
Trinity SpeedGems Pro Amber 17T Double Motor
Novak XRS Reversible Sport ESC
Trinity 6C 4200 Stick Pack Zapped Sport
Or should i find a 7c battery pack instead?
Old 05-08-2007 | 03:54 AM
That set-up is really good for driftin on Tamiya Slicks!,
The 6c will be fine,
But if you want long, hish-speed slides i recemend an 14-15t!
Old 05-12-2007 | 01:15 PM
Neon_guy's Avatar
The advantage that rubber has on ABS is slightly more control on concrete. However, it also has an inflated price. And anyone familiar with it will tell you that it last about .. that long. You may get about 3 weeks of running out of it IF you don't do a LOT of driving. With practice, you can get ABS to react the same way with a 19t. And, I've seen it last forever; maybe even longer.
Also, if you want to do some grip driving, I'd get foam for carpet and regular radials for concrete. Carpet and rubber haven't seemed to mesh well (in my opinion).
g/l on all that.
Old 05-13-2007 | 12:28 AM
HoldDaMayo's Avatar
So I've got my setup... i'm using a Trinity 15x2 speed gems motor on stock TT-01 gearing with the Tamiya drift tires on asphalt... I've got the tamiya CVA oil filled shocks with the rear on medium springs and the front with soft springs, ball bearings, metal motor mount, motor heat sing, adjustable tie rods, novak XRS esc, alum prop shaft.
I'm still sort of tuning it but i'm having a slight problem with understeer at higher speeds... at lower speeds you can use the throttle to break the rear end loose but at higher speeds the engine doesn't have the power to break the rear lose... i want to be able to use weight transfer to fix the situation where letting off the throttle or tapping the break allow the front end to grip and start to bring the rear around... I'm very new to this and I can tell i have alot to learn about car setup.
Any ideas/tips?
