Tires
If I wan induce oversteer to drift. Should I use soft tires in the front and hard tires in the back? And which tire material has more grip: Foam or sponge? Or are they jsut the same thing.
For a Newb I wouldn't suggest drift tires, because until you can get good reactin time, and be able to drift good, you are going to go pretty fast when you drift. Use ABS pipe until you get better.
