TT-01D help with gearing please
my Nismo silvia drift spec TT-01D is completly stock and came with 19 tooth pinion and 61 tooth spur gear, it's lack of low end punch, what pinion and spur shoudl I upgrade to get the most out of the sport tuned motor for drifting? thanks.
RE: TT-01D help with gearing please
Go with a smaller pinion
do they make a smaller pinion? never seen smaller than a 19t tbh.
if its lack of low end punch im guessing your running a 27t stock motor,so try a lower turn motor maybe a 21-23 depending on which esc your using
if your using the standard tamiya esc dont drop lower than a 19t motor tho[8D]
as I said on the original post, it's a completely stock drift spec, so the sport tuned motor is 23T, esc is whatever came with it, which i think is the same as any other TT01
I found a 16T and 17T pinion gear set from towerhobbies, wonder if they would fit?
http://www2.towerhobbies.com/cgi-bin...?&I=LXGJ67&P=M
could do there 48 pitch metric which should fit give it a try and let us know i always found the 19t has plenty of lowend tho ended up moving up a few teeth even
