going backwards drifting style
sup guys? how you all doing?
i have made some simple modifications to my car (tt-01) so that i could try another style of drifting.
what i did is that i switched the front body posts with the rear long ones and i put the bumper on the rear. so is now the rear is the front and i reversed the body so now the rear tire are the ones that steer the car and i reversed the throtle servo so when i hit reverse the car goes straight nor back wards and i drift it. what worries me is will the motor get hert if i am always on reverse?
ON, CANADA
It might be affected, what do you mean u switched the throttle servo,
isnt it an elevtric car, or did you use and esc,
if you reversed it by switching the wires the motor might get pretty hot!
NL, CANADA
I think it would be cooler if you did not change the car at all and just tryed to learn to drift backwards. Then you could be drifting normal but just start drifting backwards on demand.
