METHOD 19X2!! WHAT TERN PINION SHOULD I USE
i got a method 19x2 turn motor n i was wondering what pinion i should use for maximum speed!!!!!!!!!!! plz help
what car is it in m8?
if its a TT-01 and u want super speed (dont drift on this combo) try the 25/55 combo i run a 19t on that combo and it shifts[8D]
ye its a tt01
how come i shouldent drift on that combo?? n i want sumfen 2 drift with..... something that would give me good acseleration speed
If your drifting bro i would use the stock gearing ie 19/61 it has much better pullaway and torque compared to the combo i said for high speed runs.
you probally could drift on 25/55 but it will suck[
highest combo i drift on is 23/58 i wouldnt gear any higher for drifting as it heats up alot.
]highest combo i drift on is 23/58 i wouldnt gear any higher for drifting as it heats up alot.
I'm using Team Orion SV2 19x2 BB on one of my TT01, I found the 20/61 work best on ABS and HPI drift T tire, best compromise in low end torque and speed for drifting.
