Help With Belts!!!
CA
Help With Belts!!!
Hey I put this in electric on-road and no one has helped me yet so here goes.....
I have a sprint 2 sport with a Mamba Max and a Castle CMS-6900Kv motor. My Problem is that my rear belt is wearing itself to death on the case of the motor. any help???
Some kind of reply would be great.
RE: Help With Belts!!!
Tighten the belt tensioner and the drive center shaft mounts. It should get the belts off the motor unless the belts are really loose. But it will definetly tighten your belts a little more.
CA
Thanks A mil I did what you said and guess what? It worked. so now I can drift til there's no tomorrow....
Thank you again.
~Doc~
Thank you again.
~Doc~
