TA-05 Drift Setup
TA-05 Drift Setup
Ok i am setting up my TA-05 for drifting... It currently has a venom 17 turn motor, Traxxas XL-5 ESC, and electrical taped tires. What else do i need to set this thing up?
PA
RE: TA-05 Drift Setup
Get the Tamiya Spool and put it in the rear end to replace the ball diff. Lower the chassis to a couple MM off the ground and your are good to go.
