Battery charger????
lol forgot to put this but will this work?
http://cgi.ebay.com/Pro-Peak-20-Amp-...742.m153.l1262
ME
i dont think that would work, i suggest getting this battery and charger, they are both duratrax
http://www3.towerhobbies.com/cgi-bin...?&I=LXNCR1&P=M
http://www3.towerhobbies.com/cgi-bin...&I=LXXG87&P=ML
<link removed>
it was thinking of getting the Dura Trax IntelliPeak ICE Charger
<link removed>
but im not sure if the battery brand needs to be the same
<link removed>
Well in the first link, (Which is to an Auction and is against RCU policies)
Thats a Power supply, So that will be needed if your Using a 12V Battery charger for home use... instead of a Car battery...
The ICE will charge the Batteries just fine.
http://www.redrockethobbies.com/Prod...XP4002&click=2
Is this charger anygood as my first charger? I found this one, is this package any good? http://shop.vendio.com/valuebuybatte.../?s=1205749868
Leave the Smart charger alone.. it only has a 2 amp out put.. I would suggest going for a charger that has a minimum of a 3amp out put...
As a Suggestion, try for the Best charger you can afford...
I like the Triton JR
http://www3.towerhobbies.com/cgi-bin...&I=LXMAH9&P=ML
As a minimum
http://www3.towerhobbies.com/cgi-bin...?&I=LXCLD5&P=7
It has 3amp output means that a 3000mah Battery will be done in 60mins
As a minimum
AP
I got the second one the magnat mentioned. I like it, its a pretty good little charger. It is timed and you can program up to 10 differnt batteries in it. It also plays this music when your battery is done charging. It charged my 1400 nich in like 20 min or so... Its small and compact and can be hooked up to both a house and your car, not at the same time of course...
i would definately try to get the intellipeak ice or a swallow 2 and no the batteries don't have to be the same brand but try to get a decent brand batterie like intellect
ME
ORIGINAL: charmanderxd
<link removed>
<link removed>
<link removed>
<link removed>
they dont have to be they just happen to be =) also it usually means that they go together easily....and support is pretty good from duratrax (or in my exsperiance)
intelects are nice baterys some last hour or 2 which is very nice =) get 3 or 4 of them and 2 chargers or a duel that holy crap you can run all day man
good luck!!
ya ill buy the intelects battery next time, and still not sure about the charger im still deciding.
but thanks a lot you guys you guys really help me out.(WHOOOOOO! MY CAR IS COMING tomorrow
[X(])
[X(])
