Body mounting tips
I use those foam pad protecters on mine to level out and to protect the underside of the shell.
Use your first pin for teh height you want then put the foams pads on top put on shell then pins on top of that always keeps everything level that way
ORIGINAL: peetiewonder
i cut and mount before painting. that seems to help for me.
I Trim, Mount, wash and dry , Mask, then spray so much easier when you can see where the Body poll holes have to go...
ORIGINAL: Biggy88
Yah i figured out it was my chasis. but i usually trim, do body holes , mask, then wipe out with alcohol.
