different gearing
so I lost the screw to hold my pinion to my motor shaft. and I was wondering what would happen to my speed/acceleration if I went to a lower teeth count on the pinion gear? wouldn't it give faster acceleration?
got a new pinion but almost near stripped my spur gear. if i went lower teeth on the spur gear would i get faster acceleration or more top end?
Your Mesh on the Gearing would have been wrong for it to have stripped..
Just make sure that there is like only a sheet of paper width between the Spur and the pinion..
I don't think it was the meshing of the gears I think it could've been because the spur gear was 3 or 4 years old. It was the stock spur gear. And the lady at my LHS said that the reason it stripped was because I was now starting to drift it harder with lower gearing. I guess with the lower pinion gear tooth count it put more stress on the spur gear.
