need help motor problems
ok so when i 1st got my hpi drift car the motor blew itself because the settings on the remote were backwards "stock out of the factory" when it was blow i could not get the pullstart to go. well now with my new engine im having problems once again my clutch is stuck and wont move neither will my pull start i need someones help please asap!
Ummm its sounds like u may have broken a engine component (maybe a conrod), could u give some more info? can u spin the clutch with ur hand? if not u may also have a clutch spring broken locking everything up or something alongs the lines of that. more info please and if u havent already thake the engine and clutch apart
well ever since then ive put it up and left it alone. i figured the motor is blown, so my intentions are to just buy a complete new engine when i get the money, also when i had the problems the gears grinded so i need to buy new gears.
not to sound cruel or anything... but why go nitro for the slide when electric is SOOO much less hassle..
The money you spend on a new Motor can pretty much have a new electric set up done....
