RC Drifting Discuss all aspects of rc drifting here!
motor
Old 07-16-2009 | 07:22 PM
Default motor
i just got my Tc4 the other day & been practicing the drifting. but it doesnt really seem to have that much power to hold it. it has a Pro Tweaked brushed motor. i think is a 27T (not sure) not sure on what he has for the pinion gear but it also has the stock spur. so i was planning on getting a brushless setup. what would be a good 1 to go with that isnt going to be to expensive. & what size pinion & spur should i go with.
Old 07-16-2009 | 09:58 PM
SIRCC's Avatar
Default RE: motor
check the manual for the basic set-up.
Old 07-16-2009 | 10:10 PM
Default RE: motor
a cheap one is the EZRUN brushless systems or the YEAH RACING / HOBBY WING brushless system... theyr all cheap as chips and quite good little motors for drifting id go for the 9T or 13T dont go lower than 9 thats a bit much however i have one of these and theyr very good motors... check ebay etc... theyr very cheap
Old 07-16-2009 | 10:56 PM
Default RE: motor
i dont have the manual for it. i didnt get it with the car. ive never heard of either of those brands, ill check them out though. what about the castle creations mamba max. i was mayb thinking about 1 of those. but not sure what size. mayb the 5700kv.what do you think.
Old 07-17-2009 | 02:13 AM
Default RE: motor
for drifting thats a bit overbored... look up the ones i mentioned theyr cheap and durable... at most id go for 4000kv or under
Old 07-17-2009 | 06:07 AM
SIRCC's Avatar
Default RE: motor
mamba max is a excellent choice if you are going to drift. 4600 and 5700 are perfect for drifting you can even use 3cell lipo batterries for extreme speeds, you wont need to change your gear ratio, they will have enough power to break the drift wheels
Old 07-17-2009 | 06:40 AM
d.k.v's Avatar
Default RE: motor
is the 4000kv ezrun to much for a tt-01?
Old 07-17-2009 | 07:07 AM
SIRCC's Avatar
Default RE: motor
if you are getting into drifting for the first time, you should buy a system with a warranty. cheap is cheap. drifting requires high speeds and aceleration cheaper brands burnm out faster and yes its good for tt-01
Old 07-17-2009 | 11:04 PM
Default RE: motor
thats what i was thinking. i had a castle in my mini t. i want it to be able to go fast if i want. so id only have to change the wheels over. but i also want something thats going to have the power to break the wheels free when i want it to. think im going with the castle 5700. & i like having a name brand that i can trust. not into getting the cheaper stuff. you get what you pay for.
