RC Drifting Discuss all aspects of rc drifting here!
drift motor
Old 07-25-2009 | 11:33 PM
Paulyd's Avatar
Default drift motor
so i have a big plan ahead for my rc area of hobbies.
this includes:
a spektrum system,
and build a tt-01 kit.
my question is, what would be a better motor for drifting? the HPi drift meister 19t, or the reedy flash 19t? i might throw on the occasional regular tires for some high speed fun, but what one would be better for drifting? or are they essentially the same? i plan on running a dynamite tazer 12t esc, and probably some nimh battery, somewhere around the 4500mah mark, along with deans plugs.
Old 07-26-2009 | 07:04 AM
TIGER76's Avatar
Default RE: drift motor
Both should be fine m8 around 19turns if where you wanna be for a good torquey drift motor and like you said you can change out the tyres and put some speed down too,looks like youve done your homework on setting up a drift package already
Only thing i could add would be looking at the newer designed E version of the TT kit as the front end steering is designed better.
Also the motors with 19x2 etc will add more torque for slower technique drifting i used a method 19x2 with good results
Old 07-26-2009 | 07:05 AM
droppedgmc's Avatar
My Feedback: (18)
look at the checkpoint money 19T or komodo dragon 19t. i've run both, and both work well. I haven't heard any bad about the hpi motors either
Old 07-26-2009 | 09:10 AM
yeh the TT01E definatly helps a lot with the sloppy steering its till sloppy just less so haha
Just Picked up myself a TB03D chassis should look into one these things look awesome
Old 07-26-2009 | 10:32 AM
Paulyd's Avatar
ORIGINAL: TIGER76
well buying a tt-01 has been in planning for over 1 year. what happened was since that i'm also into bmx and mountain biking, that kid of took over all my time when i wasn't doing homework, and i hadnt even started my revo since like novermber, and now i need a new spark plug, and some parts for my rc18t, so i started looking into this again.
