RC Drifting Discuss all aspects of rc drifting here!
My Esc Died Help?
Old 03-31-2010 | 11:01 AM
leadfootdriver's Avatar
Default My Esc Died Help?
Well my esc is dead thanks alot Sprint 2 the wires that connect to the reciever from the esc are cut not by me but the car's front belt which surprisingly isnt ****ed up at all well now i have to replace the wires along with the connector that actually goes into the reciever do i have to get the exact same connector or can it be just a regular one like off a servo? their almost identical except mine doesnt have that little extra peice of plastic sticking off it that acts as a guide when you plug the connector into a reciever slot buying a new esc is not a option for me
Old 03-31-2010 | 11:51 AM
MaddMatt's Avatar
Default RE: My Esc Died Help?
Any one of the servo leads will work. or even if you have a junk servo laying around, you can transplant the wires from it... just make sure you have the color code in order when you put it back together. 1 wire at a time is a smart way to go.
Old 03-31-2010 | 12:34 PM
yeah I'm not good at soldering so ill have my step dad do it but other than that i can do nearly any electrical thing as long as its fairly simple but thanks for the help i got countless dead servos laying around ill do that
