RC Drifting Discuss all aspects of rc drifting here!
Help
Old 06-07-2010 | 04:57 PM
Default Help
I want this wheels for my drifter but how will I know it fits http://www.rc-race-and-drift-japan.c...oducts_id=1066SORRY I'M A NOOB AT THIS
I own a exceed drift star these are my specs.
Wheel
Base
260mm
Ground
Clearance
4.5mm
Diameter Of
Wheel 65mm
Width Of
Wheel
26mm
Old 06-12-2010 | 12:20 AM
Default RE: Help
teamnolimit,
If they have 12mm hexes, they should fit fine. 24 to 26mm width wheels seem to be industry standard. 65mm diameter? Are you sure you measured just the wheel, and not the outer diameter of the tire? 2" wheels are standard size. I've got those same wheels in all the offsets, in chrome. Be sure of the offset of the wheels you are replacing. If not, you may have wheels that stick out too much, or not enough. Also, I suggest going to a good compound tire to go with those wheels, unless you like the performance of the OEM ones.
How is the Driftstar as far as quality?
Old 06-12-2010 | 06:24 PM
kstmRYD's Avatar
Default RE: Help
you noted 65mm as the wheel diameter, that equals 2 1/2 inches. These wheels are 2 inches in diameter, are you sure about the 65mm diameter wheel?
