RCU Forums
-   RC Drifting (https://www.rcuniverse.com/forum/rc-drifting-304/)
-   -   Pinion recommendation (https://www.rcuniverse.com/forum/rc-drifting-304/11625012-pinion-recommendation.html)
Dan champ 12-28-2015 09:46 AM
Hey Guys
I have a Sakura D4 RWD that I'm building and I Have a brushless 10.5T and wanted
a recommendation for a pinion gear to use with the 92 teeth spur gear.
In advance
Dan
Rocket-J 01-06-2016 09:22 AM
I am not sure about this but don't they come in pairs? If one gets bigger the other gets smaller. The diff. case has a certain spacing so the two gears must fit each other. If they do not match they will run in a bind and wear out very fast. They also will create increased drag on one another and you will have a performance loss.
I am speaking from a real car point of view. Ring and pinion gears are always a matched set. I believe it has to be the same for the RC Cars.
