RCU Forums
-   RC Drifting (https://www.rcuniverse.com/forum/rc-drifting-304/)
-   -   Help With ABS (https://www.rcuniverse.com/forum/rc-drifting-304/2599268-help-abs.html)
monkeypunk101 01-29-2005 08:07 PM
Help With ABS
Hi i was wondering how thin does the ABS pipe need to be on the wheel by thin im talking about width , and also how can i get an even cut on the abs please help:(
monkeypunk101 01-29-2005 10:57 PM
RE: Help With ABS
I just cut the ABS 1 inch but the problem now is that the body wont fit what should i do what should i do[&o]
Kensaku 01-31-2005 06:06 PM
RE: Help With ABS
cssdev can help you. He makes them too. PM him.
WhiskyVR-4 02-01-2005 06:41 PM
RE: Help With ABS
I just cut mine to the same width the the wheel, the file the edges just a little bit to round them (yeah, it makes it look more like a tire, but I really do it because it keeps the ABS from snagging on things when its sliding)
You can get a straight cut by hand, if you are careful, or you can use a bandsaw to make perfect cuts.
WhiskyVR-4 02-01-2005 06:42 PM
RE: Help With ABS
what do you mean the body won't fit? Won't fit how?
wakefreak09 02-01-2005 08:06 PM
RE: Help With ABS
i use abs pipes to if ur body doesnt fit maybe u cut them to wide or just try lifting the bodie up on the posts and try that and see if that works but i dont understand y the body wont fit and by the way dev doesnt have the internet anymore he is movin but he thinks he will get it back cuz he isnt movin in a bit so he might be back on idk but anyways try movin up the bodie on the bodie posts and see if that helps
monkeypunk101 02-01-2005 10:30 PM
RE: Help With ABS
well the abs is as close as i can get it to the width of the rim, do you think it will be ok if i made the abs skinnier it would still slide around
wakefreak09 02-02-2005 06:16 PM
RE: Help With ABS
yeah it should be ok just put tape on the rim and slide the pipe over it for a snug fit yeah it should be fine
