RCU Forums
-   RC Drifting (https://www.rcuniverse.com/forum/rc-drifting-304/)
-   -   Basic Help... Plz Look, Very Basic (https://www.rcuniverse.com/forum/rc-drifting-304/3646492-basic-help-plz-look-very-basic.html)
Daddygodoff 12-12-2005 05:55 PM
K i need help with a couple things....
What the hell is a servo...
And if i get a stock TT-01 ppl have said i need to get a new ESC because it heats up too much... is this true ?
What is the role of the ESC...
How much should i be paying for a higher than average car...
Spdsk8er 12-12-2005 06:11 PM
RE: Basic Help... Plz Look, Very Basic
ORIGINAL: Daddygodoff
ok. so u are a TOTAL NEWB. ok. a servo is a mechinisim that steers the car. as for the TT-01, the stock esc is fine. it does not overheat, or anything.
oonoiroo 12-12-2005 06:15 PM
ESC is what controls the speed of your car. If you hold the trigger on the remote lightly, it will go slow. If you jam it, it will go fast. And yes, stay with buying TT-01.
Daddygodoff 12-12-2005 06:19 PM
any hop-ups i should get right when i buy it ?
what are the first hop-ups i should be buying ? bearings seem common but i dont understand bearings... like i know what they are but are we putting them in the wheel or somewhere in the motor ? and why wouldnt there be bearings in the wheels already ?
oonoiroo 12-12-2005 07:46 PM
For the TT-01, the hop-ups that are highly suggested are the aluminum drive shaft and ball bearings.
Bearings make moving parts(such as the drive shaft, differnetial, and axels) move more smoothly.
Daddygodoff 12-12-2005 08:36 PM
SO I SHOULD GET THOSE PRETTY MUCH WHEN I BUY THE CAR RIGHT ???
DOES IT COME WITH AN INSTRUCTION BOOKLET OR MANUAL I CAN USE TO INSTALL THE PARTS ????/
gogita502 12-12-2005 08:40 PM
not really... i'd say ball bearing are important to buy. and tires
oonoiroo 12-12-2005 09:12 PM
Sure.
Daddygodoff 12-12-2005 09:39 PM
ok thx.... what about higher hop ups?
shocks, motor, ESC ???
chicoRC 01-10-2006 10:05 PM
Can i use NiMH batteries on the TT-01 series? The chassis says NiCD but i have tons of NiMh and i dont feel like buying a separate charger and batteries.
RC-Drift UK 01-11-2006 05:56 AM
NiMh are fine dude
ESC is a must
...and servos come with the radio gear, it's a black rectangular matchbox sized plastic thing with a star screwed on (google for "futaba servo")
rcnobody 01-11-2006 04:31 PM
@ daddygodoff
if you order the ball bearing set and install upon assembly just replace the stock bearings with the ball bearings, its a very simple process. also a motor is a must the stock 540 just doesnt cut it...i first upgraded to a venom 21t and quickly realized this as well wasnt cutting it i recomend the reedy quad 18t by associated. any more questions on your tt-01 just ask.
nitros_rule 01-13-2006 09:24 PM
no dont steer him towards buying upgraded motors and stuff yet just yet especially if hes a noob first of all learn to drive the car drive the learn to fix the car then get upgrades like motor esc ect.are u gettin a rtr or kit if its an rtr pull it apart then put it back together youll lern alot by doing that.if you think your gonna have trouble remembering how to rebuild it take digital pictures as you go then u can refer to them when your rebuilding.a quick and easy upgrade is deans plugs.
_iceman_ 01-14-2006 12:49 AM
this might sounds stupid put i'm geussing that your perity new make sure that your NiMH battarys are 7.2 v not 9.4 dont want to blow it up;)
