RCU Forums
-   RC Drifting (https://www.rcuniverse.com/forum/rc-drifting-304/)
-   -   abs boiling/baking? (https://www.rcuniverse.com/forum/rc-drifting-304/4126563-abs-boiling-baking.html)
s20700134 04-05-2006 01:28 AM
abs boiling/baking?
I'm confused on the whole thing about putting the abs in the oven/boiling water to soften it. I have SOME idea, but i need to make sure. You smooth the wheel down so it's flat right? And then fit the soft abs over it?I wish someone made a turorial on this(in one post and with clear instructions). I've tried searching, but couldn't find it.
RC-Drift UK 04-05-2006 04:41 AM
RE: abs boiling/baking?
I thought about this then decided against it because it means faffing around every time you want to fit new tyres, so I skimmed about 0.5mm off the rim of the wheels and they were just a nice tight fit in the plastic tyres.
Now all I have to do is do a simple (and easy) replacement when I wear the tyres out ;)
Kev
Auslide 04-05-2006 07:27 AM
I Used a Well Ventillated Fan forced oven and a Baking tray, heated up the ABS till soft, then Shoved them over the rim
I use the same practice for PVC and they go on good and Tight
RC-Drift UK 04-05-2006 09:11 AM
Don't you get sick of doing that every time they need replacing?
Kev
s20700134 04-05-2006 11:45 PM
so the verdict is that you can either
------soften the abs/pvc(either by boiling or baking) and fit it to the trimmed wheel???
------or
------just trim some extra meat off and kinda force it on???
RC-Drift UK 04-06-2006 10:42 AM
trim the wheel once, fit replacement tyres as easy as pie...and dead fast too ;)
Kev
Wholikescheese 04-06-2006 06:38 PM
I have mounted a couple sets of abs tires on to HPI rims. Boiling is really easy and very fast. I guess I never brought the water to boil but just when it starts to steam and you can still put your hand in the pan. I took a file and beveled the tire slightly so that it would snap on easier. I could mount a set of tires in about ten minutes from start to finish.
Auslide 04-06-2006 07:43 PM
Nope I prefer baking , once the PVC/ABS cools around the rim there is very little risk of it detaching mid drift..
Removal is easy, Hacksaw Blade and a steady hand and we are ready to go again..
silent_echo 04-06-2006 09:38 PM
i didnt boil or bake...some people swear by a rubber mallet :D but for mine i needed to tape the rim or else the pip was like 1mm too big. so i just put too much tape on the rim to puch it on by hand them rubber malleted em
s20700134 04-06-2006 10:28 PM
THANKS ALOT GUYs:D
