NEW DRIFTING MOTOR..
Whats a good step-up motor from a Tamiya Sport Tuned 540 for drifting?
Right now Im using a TT-01 Chassis.. Thanks! |
RE: NEW DRIFTING MOTOR..
Specs:
6-8.4V (5-7 cells) usable voltage range 18,300 rpm at best efficiency 350 g-cm torque at 18,300 rpm peak rpm: 21,000 peak current draw 50+ amps 1/8" motor shaft |
tamiya tz 23 turn
cool! whats the diffrence from tz and rz? besides diffrence in rpms..
i have a cheap $20 19turn method motor. so far so good its the best bang for the buck. i use a 22t pinion gear and 61t spur gear.
75T lathe motor will work perfectly!
ORIGINAL: emacwizguy cool! whats the diffrence from tz and rz? besides diffrence in rpms.. great write up on the motors that helped me make my decision no clue why its not stickied http://www.rcuniverse.com/forum/m_5327872/tm.htm |
thanks guys!
Another Question: will a Tamiya ESC TEU-101BK ESC work with a tamiya tz or rz motors?
20 turns and up are good for that ESC.
| All times are GMT -8. The time now is 02:07 AM. |
