RCU Forums
-   RC Drifting (https://www.rcuniverse.com/forum/rc-drifting-304/)
-   -   Locking TT01 diff (https://www.rcuniverse.com/forum/rc-drifting-304/5456663-locking-tt01-diff.html)
myae86rolla 02-22-2007 06:04 AM
Locking TT01 diff
1 Attachment(s)
here is another way to fully lock the diff. and u can remove it to make it normal when needed. there are 3 spider gears. what u do is put the gear between the other 2 for a locked diff. hope the pics help. i learned this trick building my TLT rock crawler! i dont know if this has been posted or not but here u go anyways. thanks
milkloose 02-22-2007 01:46 PM
RE: Locking TT01 diff
hi im just a nod in drifting rc im just wondering should I locked the rear and the front differential ?? and im using a tto1 chassis :)
joeyblaze 02-22-2007 03:45 PM
does this trick allow any play, or is it just like using JBweld, wouldnt this put more stress on the drive train then say using playdo or something
Chiman2 02-22-2007 03:52 PM
hmm. i see ur testing to see if i was right or not. lol. well i think this might allow a little of play it seems to be a non messy way and good way to lock ur diff. ill be trying this later tomorow
joeyblaze 02-22-2007 04:52 PM
haha not testing you just using what i learned :) yeah this does seem like a great and easy way to lock the dif, just hope it gives a lil play like we talked about online :)
itsnotskidding 02-22-2007 07:17 PM
i use blue tack or putty, in one of my tt-01's i even put eleastic bands in the diffs, gave it play but the more i drifted the tighter it was and helped maintaine the longer slides!!...;)
myae86rolla 02-23-2007 12:02 AM
the drivetrain will handle it. if my TLT rock crawler can survive with this setup then it will for the TT01. thanks
ChuckDeez 02-23-2007 12:09 AM
ORIGINAL: myae86rolla
yeah, but crawlers are slow, and were going faster than that.
myae86rolla 02-23-2007 12:17 AM
there is more stress on the drivetrain climing over rocks than drifting. and ur spinning the tires most of the time anyways. thanks
ChuckDeez 02-23-2007 12:31 AM
i'll try it. Have you tried it yet? I'm going to perform this on my cousins. I don't want to break mines. lawl.
magnat 02-23-2007 01:15 AM
Sticking to blu-tac... its easier and proven method in drifting..
Blu tac allows movement Essentially turning the diff into a limited slip which is desired any way..
ChuckDeez 02-23-2007 01:50 AM
ORIGINAL: A.U.S.O
whats blue tac? i might try that?
myae86rolla 02-23-2007 02:05 AM
my locked diff setup works good. but u can try that blue tac way. ull experiance a limited slip effect like a real car which works well also.
magnat 02-23-2007 05:06 AM
Poster Putty?
Its the Gooey stuff you use to hang up posters, Comes in a Bluish grey color..
Playdough and silly puuty also works..
I have heard of a Full ghetto drifter using a pack of Pre-chewed bubble gum.. worked a Treat
joeyblaze 02-23-2007 04:55 PM
can some one post pics of this, i wann see how i should pack the dif
magnat 02-23-2007 05:01 PM
Will do, only thing is I have to rip my TT-01 apart to show you.. may take a few Days
driftdriftdrift 02-23-2007 07:04 PM
hmm intresting, might try it. right now my gear diff is locked up via ducttape strips. you pack a whole bunch in there and it works like an limited slip
myae86rolla 02-25-2007 06:32 AM
lots of ways to lock a diff. up to u guys to decide which is best... happy drifting!!!!
