RCU Forums
-   RC Drifting (https://www.rcuniverse.com/forum/rc-drifting-304/)
-   -   55t (https://www.rcuniverse.com/forum/rc-drifting-304/6362135-55t.html)
mark.b 09-13-2007 07:41 AM
55t
1 Attachment(s)
just put my integy 55t in my tt-01 , it drifts tottally different as the cars speed is reduced ,its so much more controlable , using sushi drift tyres , also found when i had the car stripped down to put the motor in and to apply grease to gears my tamiya propshaft pins had slid to one side leaving a very short pin on both ends ,(i had had a slight vibration when using the car the last two times i have used it ) have tapped them back in place , has anyone else had the same problem , is there a fix anyone knows about , i was thinking supergluing them into the propshaft, sorry about pic best i could do ( not my prop ,just to show the pin i mean)
Ranma 09-13-2007 12:24 PM
RE: 55t
yes super glue it just don't go overboard with the super glue
TIGER76 09-13-2007 01:51 PM
RE: 55t
will have to check my prop havent in a while[X(]
ditto on that 55 mark,just geared mine 25/55 wanna see what speed it will get running a checkpiont money motor and new 3300 packs :D
mark.b 09-13-2007 04:11 PM
RE: 55t
im running standard gearing and 3700mah nimh packs , everything went ok on the first outing with the 55t in , esc stayed cold motor was warm
quite happy with it , gonna try and go out with a fully charged pack an drift till its dead , see how long run time i get and see if the motor doesnt get too hot [sm=thumbs_up.gif]
FireStriker 09-14-2007 01:15 AM
RE: 55t
HOw much was the integy and were did you get it from ,
i plan on trying it!
mark.b 09-14-2007 12:00 PM
RE: 55t
ORIGINAL: FireStriker
i got it here http://www.lstshop.co.uk/catalog/pro...cb73d22cf31805
boltomn england , they only do a 35t now though , i am goin to get one and put it in my tt01 and put my 55t back in my buggy , as the 35t revs slightly faster
TIGER76 09-14-2007 04:18 PM
RE: 55t
You say standard gearing mark,you mean 19t pinion?surely it wont mesh with a 55t spur?
mark.b 09-14-2007 07:29 PM
RE: 55t
the spur and pinion gears i am using are the standard ones that come with the car , untill i strip the gear cover off and count the teeth on each im not sure how many each gear has
ferrarimk13 09-14-2007 09:32 PM
RE: 55t
how slow does it go now? lol like 15 mph?
FireStriker 09-15-2007 01:50 AM
RE: 55t
Slow doesnt matter for Dift, Unless ur using rubber tires!,
thx for the Link!
mark.b 09-15-2007 07:30 AM
RE: 55t
ORIGINAL: ferrarimk13
speed = racing , torque = drifting
mark.b 09-15-2007 07:34 AM
RE: 55t
i have pm'd you a closer link :D
FireStriker 09-15-2007 08:21 AM
RE: 55t
ThnX[8D]
TIGER76 09-15-2007 09:24 AM
RE: 55t
ahh my bad mark i thought u ment you were using the 55t spur on a standard 19t pinion which wont work lol :D
yeh agree the standard gearing 19/61 on a lower turn motor is best combo for drifting been using 23/58 for a while think its better for abs myslef less spin (lol i know less spin lol)
as for slow remark if i gear mine 28/55 she GPSes 31mph on a elecy that fast enough for ya [8D]
