Smoke Unit
What kind of smoke unit best suits our need? I've seen a video of an Italian drift club on YouTube where almost every single car had a smoke unit installed. I've come across two kinds on the web, one for model aircraft and the other for model trains. Which one are people more familiar with?
RE: Smoke Unit
ORIGINAL: Captain Nemo12 What kind of smoke unit best suits our need? I've seen a video of an Italian drift club on YouTube where almost every single car had a smoke unit installed. I've come across two kinds on the web, one for model aircraft and the other for model trains. Which one are people more familiar with? |
RE: Smoke Unit
smoke unit for exhuast? or is it for realistic drift action?...maybe soak a cotton ball in NITROMETHANE and light it up. stick the flame ball in a small metal cylinder and slap your setup on the car body.
RE: Smoke Unit
some of the rc tanks have a smoke unit installed mainly on the HL brand it consists of a wick which uses a heating element through a circuit board you add smoker oil which produces the smoke also using a pump system to blow out smoke,if hooked up to an rc car if will produce more smoke when more power is increased.
due to the quality of HL electrics i dont think this has been tried yet lol:D |
RE: Smoke Unit
1 Attachment(s)
i used smoke matches in a small metal tin , there used for testing chimneys to see if there clear , problem is they only last 20 seconds , need something though the cars look really good with smoke plumes :D
try ebay for smoke matches/pellets , the pellets smoke for 60 seconds but are slightly more expensive |
RE: Smoke Unit
soak cotton/fiberglass with gasoline and mineral oil, stuff them under the body shell, lit them up and start drifting as quickly as you could, instant smoke and fire ball machine. :D :D
RE: Smoke Unit
ORIGINAL: ben805 soak cotton/fiberglass with gasoline and mineral oil, stuff them under the body shell, lit them up and start drifting as quickly as you could, instant smoke and fire ball machine. :D :D |
RE: Smoke Unit
why not.....it'd be like Ghost Rider and everything! :D :D
| All times are GMT -8. The time now is 03:42 PM. |
