RCU Forums
-   RC Drifting (https://www.rcuniverse.com/forum/rc-drifting-304/)
-   -   how do u lock diffs tt01? (https://www.rcuniverse.com/forum/rc-drifting-304/8493809-how-do-u-lock-diffs-tt01.html)
kneedeeppow 02-19-2009 05:00 AM
am reading all about the pros and cons of locking and or tightening diffs in tt01s? my question exactly is what do i do to lock my diff? and what do i do to tighten? what is the difference? am running standard gears.any help would be greatly appreciated
The Hedgehog 02-19-2009 08:56 AM
RE: how do u lock diffs tt01?
JB Weld them together...
TIGER76 02-19-2009 02:01 PM
Or you can use small balls of paper,plastercine or bluetac inside the diffs to semi lock them ;)
kneedeeppow 02-19-2009 02:51 PM
so do you fill part number gb3 & m11-13 full of bluetac?
samguan 02-19-2009 03:56 PM
just use hot glue gun and glue the gears together in the diff. then close the diff.. it's super easy to remove later if you wish to unlock as you know hot glue don't stick to metal gears.
kneedeeppow 02-19-2009 09:02 PM
so glue the bevel gears together?
Druss 02-20-2009 11:53 PM
ORIGINAL: kneedeeppow
yes, just fill in all the space, when you close and tighten the diff case some glue may leak out. that's ok. I use some of my sons silly putty.
If you use glue just let it dry before you put the diff back the car.
smart racer 02-21-2009 05:27 AM
if it is he set-up as the TLT...just place the bevel gears beside each other...so you can still unlock if you want
