confused
hi guys, i am a complete beginner when it comes to electric rc cars normally use nitro. but drifting looks too good to not have a go!
whats the difference between a brushless motor and a normal motor? whats the best battires to use (to get the most run time) the car i have just got (yokomo mr4tc) has got a 17 turn motor. i have seen motor that go down to 4 turns, which are the best to go for and what is a turn? is more or less better. thanks for any help in advance mike:D |
RE: confused
ORIGINAL: sjmikey hi guys, i am a complete beginner when it comes to electric rc cars normally use nitro. but drifting looks too good to not have a go! whats the difference between a brushless motor and a normal motor? A brushed motor uses brushes that ride on a com with magnets surrounding it. a brushless has no brushes, the electrical field surrounds the center rotor. a bl motor is virtually maintenence free, up to 20% longer run times whats the best battires to use (to get the most run time) best to use would be a lipo battery. you get constant power until the lipo hits it's cutoff. a nimh is the next best, but power tappers off towards the end of a run. lipo's have no memory, so charge when you want. nimh, it's best to discharge then recharge the car i have just got (yokomo mr4tc) has got a 17 turn motor. i have seen motor that go down to 4 turns, which are the best to go for and what is a turn? is more or less better. Most drifters use a 19t - 15t brushed and 13.5-7.5 bl motors. These produce plenty of torque and power for getting it sideways. I used to run a mr4tc special and ran a 15t in it, then switched to a 10.5 bl. both combo's worked well. my main drift motor is a 10.5 thanks for any help in advance mike:D |
| All times are GMT -8. The time now is 04:22 PM. |
