whats so good about 2.4 ghz?!?!?!?
RE: whats so good about 2.4 ghz?!?!?!?
TBJ, when it comes to 2.4 Ghz discussion, you sound like the lipo/brushless motor hater crowd who want to hold on to their dear decade year old Nicads/Nimh and brushed 8t motors for racing and speed runs. Well, except you're not claiming 2.4 Ghz will catch fire and burn the house/car/whatever down.
OH
Downunderdog, it is not necessary to forgo the use of pronouns. ThunderbirdJunkie should know; he does it all the time.
At any rate, it's pretty much beating a dead horse at this point. Why bother regurgitating the same exact posts every single time? It doesn't mean the feelings have changed, it simply means that there is no point in continuing to post the same thing. You can go back to the post you're referencing and revisit ThunderbirdJunkie's reasoning for yourself. There is absolutely no reason to continue asking. After all, it's so fresh in your mind that you can recite it word for word.
OH
ORIGINAL: Haddi Taha
thunderbirdjunkie loves brushless and lipo doesnt he
#32
ORIGINAL: ThunderbirdJunkie
ThunderbirdJunkie: CD...alternatively...…could you tell us the advantages of 2.4ghz DSM over 75mhz PCM, outside of frequency conflicts?
Just curious how much research you've done on the subject.
Slo-V Flyer: I understand you asked Cummins driver, but I can answer this. That's easy. The advantages I've gained are I no longer have any sort of RF glitches in my radio control upon startup with any brushless setup I own. With 75Mhz FM, and more so 27Mhz AM, I had problems getting any further than 20-30 ft in front of my street, on one side, and maybe 75-100 ft on the other direction. With the FM, it seemed to work with my Emaxx using the same Mamba max esc and lipo power, but glitched regardless at random places. That includes going over humps, and bumps in terrain (not hops or ramps, 2-3ft "hills" and downgrades that block LOS).
With the 2.4 Ghz, I have driven out further on the very same street in every single setup I had issues with before with no adverse affects, which I got from my FM…
ThunderbirdJunkie: Honestly, ThunderbirdJunkie does not think highly of the 2.4GHZ DSM band. At best, it's AS GOOD as 75mhz FM…
Commentary: Here Thunderbird Junkie says that 2.4ghz is NOT better than FM. (Downuderdog assumes that the "75" was a typo.
Slo-V Flyer: Just curious, what experience do you have or research have you done on 2.4Ghz to attain that conclusion?
ThunderbirdJunki: A lot.
Apart from frequency conflicts, there seem to be no advantages using a good 2.4 DSM radio over a good 75mhz FM (or even AM) radio.
Commentary: Here, ThunderbirdJunkie gives a vague response to a question that he had asked someone else and gotten a specific response to. That seems unpolite to Downunderdog, and giving ThunderbirdJunkie the benefit of the doubt, rather than making Downunderdog believe that ThunderbirdJunkie was impolite, it made Downunderdog suspect that ThunderbirdJunkie was just giving a vague answer because the definitive answer would not support ThunderbirdJunkie's point. In Downunderdog's opinion, it is better to be wrong and evasive than impolite. Downunderdog also noted here that ThunderbirdJunkie had also conceded that there WAS an advantage to 2.4ghz here, contrary to Thunderbird's previous position on the subject which had been detailed in the post quoted further above. (for clarity, "At best, it's AS GOOD as 75mhz FM" changed into "Apart from frequency conflicts, there seem to be no advantages using a good 2.4 DSM radio over a good 75mhz FM…."
Downunderdog: So, 2.4 Gig doesn't have the worry of frequency conflicts, has less glitching, shorter antennas, as good or better range, and is cheaper.
What, specifically, did your research uncover that makes you believe that FM is better?
Commentary: This is where Downunderdog began to seek clarification of the results of ThunderbirdJunkie's research.
ThunderbirdJunkie: …(in response to the quote "shorter antenna's than AM of FM") This is the only tangible advantage for ThunderbirdJunkie. He goes through antenna tubes in SCT more than all other parts combined…
Commentary: Here, ThunderbirdJunkie concedes another advantage of 2.4ghz, and has yet to list any advantages of FM.
ThunderbirdJunkie: (in response to "So why is FM a better option than 2.4? " in the same post as the previous quote) Never said it was. Just said that 2.4DSM is not better.
Commentary: Here, ThunderbirdJunkie has changed position from "At best, it's AS GOOD as 75mhz FM…" to "Never said (FM is a better option than 2.4). Just said that 2.4DSM is not better." However, ThunderbirdJunkie does not clarify why it is not better. ThunderbirdJunkie has acknowledged the benefit of lack of frequency conflicts and shorter antennas, but still reiterates that 2.4DSM is not better. So Downunderdog requests clarification (see below)...
Downunderdog: How do you define better? Because you don't seem to disagree that:
- 2.4 has shorter antennas
- 2.4 is free from frequency conflicts
and I don't think that you disagree that 2.4 glitches less (or do you? you haven't really said)
What about FM is BETTER than 2.4 Gig? If it's nothing, then the above 2 or 3 (agreed upon) improvements that come with 2.4 Gig DO make it better. All you've done so far is concede that 2.4 gig is better in some respects than FM, but then say that it's not better overall. What tips the scales back towards FM? The fact that you already have the gear?
ThunderbirdJunkie: Reliability and ease of service outweigh the advantages that 2.4 has. Why are you getting so angry?
Downunderdog: I'm not angry at all. I'm just curious what advantages you think AM and/or FM have over 2.4G. So far, you've agreed that about some of the advantages of 2.4G (shorter antenna, no frequency conflicts) and have not disagreed with the argument that it glitches less (other than bringing up the anecdotal "tell that to the guy who crashed his jet". This is the first time you've said anything about any disadvantages of 2.4 Gig compared to FM.
What has your research indicated with respect to reliability and ease of service of 2.4 G systems and how it is worse on 2.4G than FM? I haven't seen any complaints about 2.4G reliability issues, and how is it less "easy to service"?
ThunderbirdJunkie: (No response to the question)
#34
My Feedback: (349)
What's great about 2.4g is that you have more than a one mile range. So, you can (and people at my club do) fly your plane one mile high (5300 feet), which we confirmed with altitude recorders attached to the planes.
Next greatest thing about 2.4g is that you can blame your crashes on 2.4g technology lock-outs that have been claimed by several people. This saves your male ego!!
#35
What's great about 2.4? Less interference from other sources. Oh, and there's this other thing now called telemetry. COOL!
#36
TX
ROFL this thread is entertaining. Some people cannot concede easily. I am guilty of that now and then, too, I'll admit.
< Message edited by Airplanes400 11/11/2010 8:41 AM >
Yes I've heard of this issue on the "other" forum's FPV threads. This is one issue where FM may help/not be susceptible I think?
One advantage AM/FM may have for ground R/C is better obstacle penetration, i.e. ability to not lose signal or control as easily when the truck is out of LOS from the 2.4 GHz transmitter (lots of trees or walls etc.). With that said, I've yet to conduct any LOS obstacle based testing with my Fut. 2.4GHz system. Maybe one of these days.
#37
DUD (no offense, that is just what your initials spell), i think what TBJ meant was that 2.4GHz is good but the few things it has that 75MHz doesn't have isn't enough to make it "better". if they had some other real advantage other than no frequency conflicts (which, by the way, was some what fixed but the advent of synthesized radios) and the shorter antenna there is no REAL advantage for his use.
#39
TX
ORIGINAL: cumquat
DUD (no offense, that is just what your initials spell), i think what TBJ meant was that BRUSHLESS MOTOR is good but the few things it has that BRUSHED MOTOR doesn't have isn't enough to make it ''better''. if they had some other real advantage other than no COMM AND BRUSHES (which, by the way, was some what fixed with the advent of small CORELESS MOTORS) and the LONGER RUNTIME there is no REAL advantage for his use.
Hmm I wonder how that sounds now? I have a feeling that 2.4 GHz only suites those who have a need for it, otherwise as evident here quite obviously, a few others have no need for it if their AM/FM radios work for them. Or they are too used to those radios and don't want to dish out money for something they, in their particular case, have no use for. That can be understood. But to say 2.4 GHz has no *real* advantage is not accurate. I have recounted several times along with other members where exactly the FM system failed consistently and the 2.4 GHz radio shined and worked flawlessly.
#41
CA
ORIGINAL: downunderdog
Why does ThunderbirdJunkie think Downunderdog is mad? Downunderdog is confused as to why ThunderbirdJunkie makes statements that are similar to "Other than the benefits of it, there aren't really any benefits to it. And the other system that is worse is better." Downunderdog is just trying to understand ThunderbirdJunkie's point, but so far ThunderbirdJunkie has offered very little in the way of clarification, other than obfuscation, which hasn't helped and only makes Downunderdog curious and inquisitive.
Apologies if Downunderdog sounds angry. Downunderdog is just seeking clarification of the statements that ThunderbirdJunkie has made about ThunderbirdJunkie's research into the subject... which is starting to sound less and less like what Downunderdog considers to be objective research.
Edit: Dang, this lack of use of pronouns thing is tough!
i think the bottom line is that if you are using a AM/FM radio and are happy with it, by all means, continue to use it and have fun. if you are new to the hobby and looking for a radio, 2.4gig is the better option. that cannot be questioned...
#42
OH
< Giant wall of text >
Do you even know what you're asking?
#44
So you're saying that anybody with a properly functioning FM setup that is happy with it should throw all of their radio gear in the trash and begin anew with 2.4?
As ThunderbirdJunkie seems to have misunderstood or did not fully read the previous questions, what Downunderdog asked was:
How does ThunderbirdJunkie define better? Because ThunderbirdJunkie doesn't seem to disagree that:
And the last questions Downunderdog asked... "What tips the scales back towards FM? The fact that you already have the gear?" seem to be the pertinent ones.
It now seems to be obvious to Downunderdog that:
- ThunderbirdJunkie has FM gear that is working fine for him (as it does for a lot of people)
- ThunderbirdJunkie recognizes that there are some advantages of 2.4G over FM (another way of saying this is that 2.4G is better than FM, if Downunderdog understands the interrelationship between "having advantages" and "being better")
- ThunderbirdJunkie does not believe that the advantages of the better system outweigh the cost of replacing his existing gear.
Downunderdog actually believes that the ongoing migration from FM to 2.4 GHz is making FM look more attractive to those who haven't made the switch - less chance of frequency conflicts and probably a good market to pick up used RX's.
Downunderdog just had a problem with the seemingly ThunderbirdJunkie-contradictory statements that ThunderbirdJunkie was making and the lack of clarification of such statements that ThunderbirdJunkie was offering.
#47
Willystylz Date 11/12/2010 1:26 AM
I personally think the only person allowed to talk in 3rd person is TBJ...
I have been doing it with ThunderbirdJunkie because we seemed to have a communication problem, and I thought it might help if I spoke his language.
redfisher1974 Date 11/12/2010 1:04 AM
TBJ has a Nemesis, Awesome.
#48
CA
ORIGINAL: redfisher1974
TBJ has a Nemesis, Awesome.[&:]
#49
It's a lot of work remembering to not refer to yourself as ''I'', and a lot of extra typing!
