LifePO4 batteries?
#51
RE: LifePO4 batteries?
To be frank, testing of Lifepo4 cells on RC-Monster has found them pretty wanting for performance, even with nimh as a benchmark. One a123 pack dropped to 2v per cell under a medium load that saw a cheap lipo run 3.2v.
I'd stick to lipo, danger is all around you anyway, you just have to think about what you are doing. If you walk across the road without looking, you are more likely to get hit by a car, if you mistreat a lipo, you are more likely to have a fire.
Fairly simple.
Fairly simple.
#52
NC
Also in the video, where's the car? I know how hard it is to get a burning lipo out of a heli. I can't imagine how it could be any easier to git it out of a car unless when he crashed he didn't have it secured properly and it ejected which resulted in damage causing the fire..
#53
Banned
PA
ORIGINAL: savagecommander
what kind of reviews have yous seen?
ORIGINAL: electricrc68
idk but now that i see some of the reviews of the lifepo4 batteries, im going to stick with NIMH for now.
#54
Banned
ORIGINAL: shenlonco
If you want safe better performance from your batteries go with the lifep04 hobbyking has them for like 25 bucks or so for 2s 45000MAH.
Zor
#56
My Feedback: (14)
okay im thinking i will go with lifepo batteries. have you guys heard anything about A123 batteries?
If you want good performance out of li-fe packs a GOOD balance charger is a must. When they go flat its not much warning either, battery plot looks like it just falls off a cliff.
Testing with a volt meter tells you nothing as to how many mAh's are left in the batt. batt discharge voltage stays that flat. Cycle your life when you first get it just to confirm its capacity. run a few flights with it and record the time of use mA back in after each flight . This will give you a idea of how much batt life you have.
Like i said when these puppies run dead it is all at once, barely any warning and its lights out.
#58
My Feedback: (14)
best bang for buck for your use IMO would be lipo. yes they do catch fire, yes you need to balance charge for best results.
yes charging indoors is not a great idea, and it must be supervised the whole time. (dont take long tho you can charge em at such a high rate) I use em in my foamy planes. Charge em in a old crock pot with a ceramic lid. 5 years and never a problem. I seen it before in this post and will repeat it as i agree 100% 99% of all these lipo fires are created on purpose. a old cell someone wants to see burn cause they heard it was spectacular. Look at the amout of lipos in use.....how many actual failures are there? (other than people not treating them correctly)
A hard case so you dont puncture em and yer set to go. I store my lipos in that crock pot also there are a few saftey concerns sure. but it gets blown WAAYYY out of proportion.
#60
idk. they still scare me. im staying NIMH.
And when they go they can burn for several minutes. what's worse is seeing people
accidently charging a lipo on a NIMH setting...it happens all the time.
I dont think you can send a puffed lipo back to the company either.
At least I wouldnt, that just wouldnt be right, it could actually let loose in the mail truck.
Then you'd be in deep doo,doo.[&:]
#61
Banned
PA
yep. and the other thing is when a lipo blows, your rc car is going to blow if you keep it in there for too long. so thats why im staying with nimh. or i could try lifepo4, but im not really confident with lifepo4's either.
#63
What are you thinking of using them in what's the RC set up motor esc?
#64
Banned
PA
well im going to be buying a ez-run BL setup.
#65
My Feedback: (14)
If thats what you are comfortable with, by all means run it. Didnt mean for it to sound like lipos were the end-all in batts. i have nothing against nimh. used for years with great results. Still use them for my ignitions and smaller planes.
the idea iwas trying to get across is you plan the batt setup so you run under its rated load, not at or just over it. Running max draw constantly is where the problems arise.
The lipo reccomendation was simply the best way i see to achieve this. has a much greater power density.
on your rc car this should be much easier to achieve as the weight penalties are not near as bad as they are on aircraft. Not saying to run your car at the 60-70% power level, set the batts up so you can run max amps to your car with a reserve. use about 80% of the USABLE power in the batt and recharge. I only use 50-60%. Keep in the middle of the usable batt power and you will never have a problem.
#68
If you want a good priced US dealer for A123's look at this site: http://epbuddy.com/index.php?main_pa...khp7lsfdndqo21
#69
I have been in the hobby for about 8 years now and used NiMH and LiPO. For me LiPO is a no brainer once you understand them.
Get a decent balance charger
Get a LiPO storage bag or ammo can. I have both.
Balance your battery to the ESC to the motor. (make sure the battery has a bigger Amperage than the ECS which is bigger than the motor.)
Do Not store them fully charged
For me the power capacity, long run times, constant voltage and light weight of a LiPO is worth the risk. I mean I use gasoline (petrol) in my 1:1 car and lawn mower which is way more dangerous IMO.
I have had one NiMH fail, probably due to abuse using it in a brushless setup, It was soo hot I could hardly touch it when the run finished. it blew up when I chraged it.
By matching my rig, my LiPO's stay cool.
As a wrap up yes LiPo's can be dangerous, but then again any high power battery can be dangerous.... read up on them, get the right kit and don't abuse them.
Take care and enjoy.......
