hyper 10tt set up
hyper 10tt set up
hi all
I was wondering what is the best set up for the hyper 10 tt. i will be using it on grass mainly as i cart find a track near me. Would like to get alot of top end speed as well as torgue . motors i currently have are,castle 4 pole 4600kv, 3990kv motor, castle cm36 5700kv, 3300kv motor, 2800kv motor, and ezrun 2700kv i have just ordered the 3300kv,3990kv 2800kv are all 2 pole motor i got from hobbyking for car set ups. the ESC i am using is xe-run 80a, would like to be able to reach about 60-70mph on speed runs on 3s and still have enough torgue and speed to power through grass or big 1/8 track if I can find one. have also ordereda fewpinion so i will have 12t, 15t, 16t, 18t, 20t, 21t, 23t, 25t,
will the battery make a big difference currently using 3600mah 30c 3sand 4000mah 30c
3s turnigy, will be ordering(4)5000mah 60-110c li-fe 3s and (4)5000mah 40c 3s after christmas
thanks filly
thanks filly
Moderator
RE: hyper 10tt set up
Use the 3300 KV. None of those motors go 60 to 70, so the 3300 is between all of them.
And gearing- Higher pinion tooth count=more speed, so decide for yourself.
And no, those 2 batteries have little diffrence.
