flash esc
flash esc
You have three cables. Awhite, a black and a red on.
Red is voltage +, black is voltage - and white is signal.
As long as you connect them the proper way you done. See the servo plug the you use for the steering to see the orrientation. Just replicate it for the esc cable. If the plugs dont fit (or the orrientationis different) you can make a connector using an old servo cable (assuming you have one-of you dont you can probably get an extension cable from you LHS and cut that)
or you can even solder the cables directly in the receiver (NOT recomended but it depends how desparate you are-I was so I did it)
