hpi blur question
WI
hpi blur question
i have a brushless setup but the speed control burned up, its a vxl3 esc and a tacon motor. i was wondering of an hpi blur esc will work with the motor, or if the blur setup will work on a slash, i know the setup is from a 1/12scale truck need to know by tommarow tho thanks
RE: hpi blur question
ORIGINAL: Ducat1
OH
The Vapor (Sidewinder "Pro") is in the XS, the Blur is the rebadged MMM in the Flux HP.
The only issue with using the MMM/Blur in a 2 or 3S application is the BEC is set up to work with 4, 5 or 6S. Which actually may not be an issue at all, since it won't be stepping down voltage as much as it normally would?
You should be good to go. Just get some 6mm-to-4mm bullet connector adapters and you should be golden.
