my team associted sc 10
RE: my team associted sc 10
Is your SC10 an RS or a brushed RTR? I just found a used SC10RS on Craigslist so I jumped on it. I'm working on it at the moment trying to get it setup the way Iwant it. It needed a body thought, so Iwent with the JConcepts BAJR. It's kinda of a futuristic looking Baja-Bug inspired turtle shell of a body. It's different.
NJ
I personally don't know. I've only heard people running 58,60,62 spurs and 12-14T. I have a 62/14T and it's pretty good for me, stock but its holding up. lol
NJ
With the sway bars and the Hot Bodies Beams tires (red compound) I am able to cut these corners and and shaving time off my laps. I suggest these tires if you have that hard, compact clay track nearby. The stock tires that came with the RTR I have set away and only going to be using them for loose dirt & bashing.
Hot Bodies Beams SC Tires
http://www.amainhobbies.com/product_info.php/cPath/1_26_1252/products_id/174704/n/Hot-Bodies-Beams-Short-Course-Tire-Pink-2-No-Foam
They usually have these tires set up for a 1/10 Buggy for the rear. Works wonders on the SC 4x4's.
#33
NJ
Between 35-4000 kv seems to be the best way to go for the bl motors. But if you're going to bash it around then go as high as the wallet allows. Lol
