spur gear issues
spur gear issues
I have 1/18th scale dirt modified body changed over from the late model body and the dual disk slipper clutch ! I need another spur gear for it and all that is available is 60 tooth LOSB 1137 ! Can't seem to find any higher or lower spur gears ! Can you get them in metal? Also run on banked dirt oval in the summer about 50 ft track, what pinion and spur would you recommend for a 5400 kv motor ?What pitch goes with the spur gear LOSB 1137 and pinion as well ? Also we race on flat cement with the Late model converted back with the same chasis in the winter ! What pinion and spur do you recommend for a 16 to 18ft track area 10 ft wide?
