New Guy with New Toys
Hello all. Ihave been using this site to answer my many questions lately and figure it is time to get in the mix. I got into RC trucks about 2 weeks ago and cannot get enough. Two weeks in and Ihave a 2wd Stampede and a Slash 4x4 VXL and am constantly messing with them. No major upgrades yet, mostly cosmetics and suspension tuningbut Ican see this will be a long road to "almost happy, just one more thing". Spend most of my time bashing in the front yard, and the rest on the track (Shout out ot Mike's in Carrollton, TX) Here are some pics of my trucks and one in action. In the words of General Custer, bring me my radio....its time to break some a-arms!
RE: New Guy with New Toys
hey PacRat, welcome to the boards! Nice toys. These things ARE all kinds of fun, aren't they? (Except when something breaks) I've been in the hobby going on my third year and I'm totally obsessed too. Good thing it was my wife who got me my first RC, she can't complain now! It's all her fault! I'm retired, live on ten acres in the foothills of the Sierra Nevada. I've got two Evaders and have laid out an off-road track out in the middle of the property. My buddy, who also got addicted, comes up about once a week for "race days", and I run at least one batt pack a day on my own. God, I love California!
So tell us a little 'bout yerself.
ORIGINAL: Pacrat77J
ORIGINAL: Pacrat77J
welcome to the hobby now leave all your money at the hobby shop
Just practice restraint or you will go into dept pretty bad like me. Wish I learned restraint when I 1st started like I have now I think I've only made 1-2 RC purchases in the past 6 months (parts like tires yesterday), and will be making one probably next week (parts again)
Thanks for the welcome. The slash rims/tires are only for loose terrain, putthose guys on the street and its traction roll city. Ya, its real addicting and learning that $8 parts add up fast! i keep telling myself it's dont buy it till you break it from now on, but we'll see.......... Ihave a wish list started already, baja body, trenchers, wheels, speed lipo charger, aluminum everything, on, and on, and on. any suggestions for either rig would be greatly appreciated.
ORIGINAL: Pacrat77J
Thanks for the welcome. The slash rims/tires are only for loose terrain, put those guys on the street and its traction roll city. Ya, its real addicting and learning that $8 parts add up fast! i keep telling myself it's dont buy it till you break it from now on, but we'll see.......... I have a wish list started already, baja body, trenchers, wheels, speed lipo charger, aluminum everything, on, and on, and on. any suggestions for either rig would be greatly appreciated.
Aluminum I find is good for the following(depending on model this is just in general): C-hubs, knuckles, Rear carriers, steering(only is the stock has too much slop), shock towers.
Things like arms, gearbox covers, and other things aluminum is very counter productive as it adds a lot of weight, and transfers the kinetic energy(in arms cases) to the next weakest piece pretty much multiplying the force to greater than it was designed for causing failure(breakage) way easier.
for most things on traxxas RC's get RPM parts when they break they cost a few bucks more than the stock part, and are generally way more durable.
ORIGINAL: SyCo_VeNoM
Only do that if you want to place it on a shelf as a conversation piece. Trust me that was one of the things I did when I 1st started, and turned out to be a completely terrible idea that was a huge waste of money.
ORIGINAL: Pacrat77J
ORIGINAL: RickWoo
Agreed - everything but the shock towers, they tend to bend like pretzels.
Like the DF-02 alum shock tower does tend to bend easily due to the way it was made with cast aluminum, but can be strengthened with a piece of fiberglass, or T-6 aluminum screwed on top(well in the DF-02s case it also stops the mount point from snapping off so its kinda needed either way
My shock towers on my ofna RC's are aluminum, and made from CNC'd T-6(I think as they don't give at all). A piece of 3mm thick T6(aircraft grade) can take a hell of a lot of force before it will bend as when I made a chassis plate it took all my weight bouncing on it to bend a 2 inch wide piece by 4 degrees (and broke the bolts holding my vice to the workbench, and almost flipped the bench). For comparison as to how the grade can effect the strength I bent my DF-02 shock tower back into shape with my bare hands and it was a bit thicker than the T6 aluminum.
Now cheap stuff like integy cast aluminum yes that will bend like a pretzel. CNC'd pieces will be way stronger then them.
But yea should have put shock towers as dependent on the RC as they aren't always needed.
well that depends on the aluminum quality, and the design(which is the same with the plastics)
ORIGINAL: RickWoo
ORIGINAL: RickWoo
I was referencing what's available for the OP's models, not your 1/8 buggy.
ORIGINAL: RickWoo
Best advice though in general if it says Integy its pretty much crap that is a waste in money (seriously I only know of 1 integy part that works fine) unless you want an interesting conversation piece to put on a shelf(or what is referred to as a shelf queen). For shelf queens Integy is the #1 parts supplier
For these Traxxas vehicles you'd better look more at RPM parts. I have a couple pieces and it helps the truck last longer. You don't need to replace everything, just replace a broken part with a new RPM part whenever you break something.
Only went specific for clarity that not all are bad, and also wasn't referring to a 1/8th scale buggy I was looking at me 1/12th scale ofnas when I said that stuff, and the buggy I did refer to was 10th scale
ORIGINAL: RickWoo
ORIGINAL: RickWoo
ORIGINAL: BKoz559
Good advice, thanks guys. This is thestuff that can definately save me time and $$$. i like the aluminum c-hubs and knuckles so may go with those when i need em. Any parts that need to be replaced now with tougher components to keep from breaking one part that bends/breaks a mess of other ones?
IL
Welcome to the hobby/obsession.
If you can help it, I say just wait for stuff to break, and then get upgrades. It's easy to get carried away and spend a fortune up front on upgrades.
Well, the bug got me again and I ordered new tires and wheels for both trucks. Proline Caliber for the Slash and Trenchers for the Pede. Will post pics when they come in. Got a good lipo charger too. The 6 hour wall charger was about to make me hurt kittens. Got a Hitec X1 6A, 50w charger. The price was doable and will suit my needs (for now).
Badlands are nice on the pede also. I'd like new tires for my converted rustler. (that was fun) nitro 2.5 to brushless lipo... stampede/rpm hubs, axles,hexs (front end hex hub conversion) 4x4 hexs instead of bearings)
I also vote rpm instead of alum. Integy make a cheap cooling fan and bracket, other than that.. they have nothing for me.
New mods to both trucks and thought i would share (mainly cuz most of my purchases are based on what i read here anyway).
Slash:
Body
GTR shocks
Roll bar - not real functional but good for some "what the hell is that?"
Caliber Tires
XeRun 4000kv motor and 120A ESC - fast!!
Stampede:
Rustler Body (hid the antenna too)
Velineon system from slash - mmuucchh better
Trenchers
NEW TOY!!! Buddy gave me (yes, free) his Revo 3.3. Didnt run, so i am in the process of converting it to electric. Should be a monster. Any motor and general build suggestions will be greatly appreciated.
Slash:
Body
GTR shocks
Caliber Tires
Stampede:
Trenchers
