==What amperage ESC do I need??==
ON, CANADA
I recently burned out my esc (water). I'm using this motor: www.losi.com/Products/Features.aspx This is the ES Iburnt out: www.losi.com/Products/Features.aspx
The original ESC was 70A. Could I use a 60A or 80A instead?
These are the ESC's I've been looking at:<xml><officedocumentsettings><o:relyonvml></o:relyonvml><o:allowpng></o:allowpng></officedocumentsettings></xml>
http://www.hobbywing.com/product_show.asp?id=279
http://hobbyking.com/hobbyking/store/__11743__HobbyKing_Brushless_Car_ESC_60A_w_Reverse .html
1 Post
RE: ==What amperage ESC do I need??==
The motor draws the current, So the rating on the esc is what it can handle. As long as the esc is rated higher then what the motor draws you are good to go.
ON, CANADA
Ah, that makes so much sense now.
I noticed you live somewhat near me. Do you know any local tracks? So far Gopher Dunes has been THE track for me.
ON, CANADA
1 Post
ORIGINAL: nitrosportsandrunner
those ESC's will not work with your motor.
those are for sensorLess motors. You have a sensored motor.
1 Post
ORIGINAL: Delta63
ORIGINAL: redfisher1974
Good catch, I did not even look that far. Thanks given.
